It is currently Thu Jul 02, 2020 1:43 pm
 Post subject: Dataloging with Freelog
PostPosted: Mon Aug 09, 2010 10:27 am
I've searched for this in the forum but couldn't find an answer so...
I'm using a chipped p28 with crome and freelog for dataloging with my AEM wideband. My wideband is wired into the ECU O2 pin and is working perfectly. But if i would want to keep my datalog setup and also run the car in closed loop is it in anyway possible?
PostPosted: Sat Aug 14, 2010 12:16 pm
Does your AEM have two analog outputs? If so, yes. Set up the second analog out to mimic the stock narrowband output and connect it to the ECU.
