Hello everyone, i've been having problem when plugging in Ostrich 2.0 in ECU.
Using 1.5.5 crome removed check sum, added quick datalogger, verified connection of Ostrich and Hulog and did every step by step process write and verify the p30 map and cycle the ignition to KEY ON position, CEL stays solid. when plugging back my old chip car ran fine, CEL shuts off.
i know that datalogging wont work when CEL stay solid
saw a post about how to make datalog work and followed it.
plug your Old Chip, do not connect the Ostrich to ECU, remove checksum, add rtp "key on", make the hulog connect start the car and live tuning works like a charm! after that i turn off the car, plugged in ostrich then CEL stays solid, no CEL codes.
Did a series of test on ostrich like testing the battery, Reset Ostrich to 28pin operation via tunerRT and checking continuity of ribbon cable but still no luck. been trying to figure it out for days now.
what seem to be the problem?
