fuse wrote:
Us this
http://www.rceng.com/technical.aspx?Use ... eS1F4XwLTW it will get you close. Try to find a similar built on line and see what his hp was. Crap numbers in you will get crap numbers out on your injector size. 1000cc should be ok. It may be a bit hard to get it to idle nice and low. Also your stock map limits the amount of boost you can use to around 10psi.
Did you set your injector battery offset? Did you play with you fuel tools offset?
What is your compression ratio now if it high you need to back out ignition timing (from a stock map) and use high high octane fuel. Are you talking 20 oversized piston, what is it a dish flat top dome, cc of piston?
its 9.0:1 dish flat top and its +.020 oversize 87.5mm dont know what is he cc of it, i never tried tuning cars yet or messing with editors but i would love to learn, i have someone to tune it and he said my injectors are too big for daily driven might need smaller in the future..i will upgrade the map sensors later on to omni 3 bar or 4 when i get to break in the motor..which one do you think is better for my setup crome or ectune? thanks
