It is currently Sun Nov 02, 2025 3:04 am
PostPosted: Tue Jun 03, 2008 10:16 pm
Im just trying to open the help on crome and it said stack overflow and then died. I just want to read the help info before asking 100 dumb qestions.
What do i need. http://www.moates.net/product_info.php? ... ucts_id=42 this chip set, a romulator,chip burner and a wide band o2 sensor. Maybe a dataloger.
I would also like to say crome looks bad ass.
PostPosted: Tue Jun 03, 2008 11:52 pm
Just a Note: I Use Crome Pro. Some of the links below have information that is brand specific, But most of the information can be used for general PGMFI knowledge.
** Books **
Engine Management: Advanced Tuning by Greg Banish
http://www.speednation.com/store/product3175.html
How to Tune and Modify Engine Management Systems
http://www.speednation.com/store/product3421.html
Building & Tuning High-Performance Electronic Fuel Injection by Ben Strader
http://www.speednation.com/store/product1649.html
** PGMFI Bible The Wiki Mirror Link **
http://mycomputerninja.com/~jon/www.pgmfi.org/
http://www.getglitched.com/pgmfiwiki/ww ... bHome.html
** Guides to get started Print these out put them in a binder and reference them often. **
http://www.xenocron.com/install/CromeGuide.htm
http://www.moates.net/zips/crome/Tuning ... 0v1.06.pdf
http://hondata.com/techtuning.html
http://hondata.com/techenginetuning.html
http://hondata.com/techpartthrottle.html
http://hondata.com/techtuneboost.html
http://hondata.com/techboostfuelandignition.html
http://hondata.com/techcamtiming.html
** Hardware Needed For Hondas **
1)_Wideband -- ( Don't be cheap Innovate Motorsports makes the most accurate wideband systems on the market, Using the least expensive Bosch o2 sensor to replace. ) http://innovatemotorsports.com/products.php
Wideband shootout -- http://www.fordmuscle.com/archives/2007 ... /index.php
2)_A Chipped OBD1 ECU -- ( You may want to purchase your 1st ECU from a Professional -- Less troubleshooting headaches )
http://www.xenocron.com/catalog/ecus-c-24.html
3)_Datalogging -- I use a Hulog
http://www.xenocron.com/catalog/moates- ... p-156.html
4)_Emulator used for Real Time Programing -- I use a ROMulator but an Ostrich works just fine.
http://www.xenocron.com/catalog/ostrich ... p-102.html
5)_Chip Burner -- Burn1 and Spare blank chips
http://www.xenocron.com/catalog/burn1-u ... -p-88.html
Hope this Helps
PostPosted: Wed Jun 04, 2008 8:31 pm
Nice thanks. So I think I’m on the rite track I have read all 3 books but thy are not system specific but are very informative. I have also already printed all the info from handata. Thank you for the 2 other links just what I was asking for I could kiss you.
I hear you can chip an obd0 and use turbo edit is this true? And if so a link I can trouble you for? Just trying to make up my mind still.
PostPosted: Thu Jun 05, 2008 8:08 am
Take a look at the old Forum 1st. If you have any questions after Feel free to PM me.
viewforum.php?f=39
viewforum.php?f=56
viewforum.php?f=60
Users browsing this forum: Bing [Bot] and 19 guests
