Just a Note: I Use Many Different Systems. Some of the links below have information that is brand specific, But most of the information can be used for general PGMFI knowledge.
** Books **
Engine Management: Advanced Tuning by Greg Banish
http://www.speednation.com/store/product3175.htmlHow to Tune and Modify Engine Management Systems
http://www.speednation.com/store/product3421.htmlBuilding & Tuning High-Performance Electronic Fuel Injection by Ben Strader
http://www.speednation.com/store/product1649.html** PGMFI Bible The Wiki Mirror Link **
http://www.getglitched.com/pgmfiwiki/ww ... bHome.html** Guides to get started Print these out put them in a binder and reference them often. **
http://www.xenocron.com/install/CromeGuide.htmhttp://www.moates.net/zips/crome/Tuning ... 0v1.06.pdfhttp://hondata.com/techtuning.htmlhttp://hondata.com/techenginetuning.htmlhttp://hondata.com/techpartthrottle.htmlhttp://hondata.com/techtuneboost.htmlhttp://hondata.com/techboostfuelandignition.htmlhttp://hondata.com/techcamtiming.html** Hardware Needed For Hondas **
1)_Wideband -- ( Don't be cheap Innovate Motorsports makes the most accurate wideband systems on the market, Using the least expensive Bosch o2 sensor to replace. )
http://innovatemotorsports.com/products.phpWideband shootout --
http://www.fordmuscle.com/archives/2007 ... /index.php2)_A Chipped OBD1 ECU -- ( You may want to purchase your 1st ECU from a Professional -- Less troubleshooting headaches )
http://www.xenocron.com/catalog/ecus-c-24.html3)_Datalogging -- I use a Hulog
http://www.xenocron.com/catalog/moates- ... p-156.html4)_Emulator used for Real Time Programing -- I use a ROMulator but an Ostrich works just fine.
http://www.xenocron.com/catalog/ostrich ... p-102.html5)_Chip Burner -- Burn1 and Spare blank chips
http://www.xenocron.com/catalog/burn1-u ... -p-88.htmlHope this Helps
