I bought a car that was already tuned with a hondata s200. I want to be able to tune it myself, without taking it to a shop and having to pay someone. I bought the $50 unlock code for data logging recently. I was unsure if I wanted to upgrade to the s300 as much as my local performance shops and hondata themselves wanted me to. After some research, I've decided to buy the gear to tune the hondata and eventually convert to eCtune or Crome Pro once I've got more experience with everything.
Here's what I've found so far:
Each company wants about $100-$200 for the ROM editor;
hondata-$200, crome-pro-$150, eCtune-$200
Most companies work with a Moates Ostrich, $180
Anything using a .bin works with Moates Burn1, $90
I have a hondata, and it didn't have datalogging unlocked, so that was an extra $50 that I had to spend.
J12 inside my ECU is cut, because it was sent to hondata for modification. I haven't opened it up yet to verify.
The hondata map won't move to Crome, but I want to eventually transition it. I'll need to make a new base map for my setup.
So, when moving from s200 to crome, can I just cut the s200 interface box wires and hook em up to this:
http://www.moates.net/product_info.php?products_id=78 [hulog]
