It is currently Wed Oct 29, 2025 10:16 am
 Post subject: brand new to crome
PostPosted: Fri May 30, 2008 1:48 am
i have never done this. burning chips is something i have always paid smeome else to do. need all the help i can get.
 Post subject: Re: brand new to crome
PostPosted: Fri May 30, 2008 11:52 am
Do lots of reading. There's a reason it costs money - it takes significant time and effort to learn how to tune. You might read the thread in my sig, go through the wiki a few times, and going through the newbie forum and reading anything with a relatively high number of views and/or posts would help. Have fun and good luck.
PostPosted: Sun Jun 01, 2008 12:33 pm
Just a Note: I Use Crome Pro. Some of the links below have information that is brand specific, But most of the information can be used for general PGMFI knowledge.
** PGMFI Bible The Wiki Mirror Link **
http://www.getglitched.com/pgmfiwiki/ww ... bHome.html
** Guides to get started Print these out put them in a binder and reference them often. **
http://www.xenocron.com/install/CromeGuide.htm
http://www.moates.net/zips/crome/Tuning ... 0v1.06.pdf
http://hondata.com/techtuning.html
http://hondata.com/techenginetuning.html
http://hondata.com/techpartthrottle.html
http://hondata.com/techtuneboost.html
http://hondata.com/techboostfuelandignition.html
http://hondata.com/techcamtiming.html
** Hardware Needed **
1)_Wideband -- ( Don't be cheap Innovate Motorsports makes the most accurate wideband systems on the market, Using the least expensive Bosch o2 sensor to replace. ) http://innovatemotorsports.com/products.php
Wideband shootout -- http://www.fordmuscle.com/archives/2007 ... /index.php
2)_A Chipped OBD1 ECU -- ( You may want to purchase your 1st ECU from a Professional -- Less troubleshooting headaches )
http://www.xenocron.com/catalog/ecus-c-24.html
3)_Datalogging -- I use a Hulog
http://www.xenocron.com/catalog/moates- ... p-156.html
4)_Emulator used for Real Time Programing -- I use a ROMulator but an Ostrich works just fine.
http://www.xenocron.com/catalog/ostrich ... p-102.html
5)_Chip Burner -- Burn1 and Spare blank chips
http://www.xenocron.com/catalog/burn1-u ... -p-88.html
Hope this Helps
PostPosted: Wed Jun 04, 2008 8:13 am
You need a ROM Burner and a ROM Emulator. The Burner is ~$100 and the Emulator is ~$200. Or, you could try building this:
viewtopic.php?f=24&t=3005&hilit=easyrtp
... heh. Looks quite scary, but it does its deed via a serial port, so the ECU can be closed. If I had a spare 'tuning' ECU, this is the mod for me.
Users browsing this forum: No registered users and 16 guests
