I just chipped a p06, and then cleaned it with alcohol. I don't know why the fuck I did that I just thought I read you should clean off all the excess flux after soldering. Anyway the coating fogged up and started to come off in some spots.
1. Did I fuck anything up? I can't test this thing for a while until I can burn a chip for it.
2. Do the goobers of balled up coating need to come off now? Does it all need to come off now that it's started? Or do I just let it dry and leave it?
3. Should I recoat it with something, if so, what.
I went back through the wiki and couldnt' find where i thought i read you should clean it with alcohol, but i didn't see anywhere saying you shouldn't.
