It is currently Sat Oct 04, 2025 5:22 pm
Post new topic Reply to topic  [ 59 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Sun Feb 14, 2010 10:48 am
Nope. It is to switch between the ECU's stock map and modified one (the one You're burning on a chip and placing in a socket). You don't have to use a switch actually, but it is quite nice to have an option to switch modified -> stock. If You solder a wire instead of using a switch You will be able to run only Your modified map.
PostPosted: Sun Jul 04, 2010 2:05 pm
Hey, can this be used on "PM7" ECU's? I have a D16A9 DOHC (ZC - what ever you fancy calling it) and i need to chip it!
Thanks Shane.
PostPosted: Sun Aug 01, 2010 10:37 pm
Should be fine as long as your ECU looks the same as the one I posted pics of.
Some of the PM7 ECU's came with a 28pin eprom which means that the whole exercise above can be avoided.
PostPosted: Mon Aug 02, 2010 2:15 pm
Usually labeled as "PM7-X04". But they are actually for o2 sensor equipped engines AFAIK.
PostPosted: Fri Apr 01, 2011 8:52 am
pictures not see please :(
for switch GND or 12v ?
PostPosted: Fri Apr 01, 2011 1:40 pm
Ground for switches
DO NOT USE 12V !!
PostPosted: Fri Apr 01, 2011 2:03 pm
My 88 civic Shuttle RT4WD D16A6 :)
I did this for pm6 (i used 10k resistor SST27SF512),
radio opened the engine at high rpmn 2700 RPM ,
When you turn off the radio is operating normally :?:
Thanks
PostPosted: Fri Apr 01, 2011 2:23 pm
It sounds like you've got some electrical issues there . .
PostPosted: Fri Apr 01, 2011 3:01 pm
radio amplifier cables ECU goes under,
I think changing the location of the cables
PostPosted: Fri Apr 01, 2011 3:12 pm
Yeah, best you relocate anything thats likely to interfere . . . buts thats for another thread/forum.
PostPosted: Mon Nov 21, 2011 2:26 am
Here is the daughterboard I designed to make chipping romless ECU's easier. I've just made a revision to clean it up and make it a little more user friendly.
Using the info from this thread, you should be able to understand how it all fits and works ...
Contact your local PCB manufacturer, I'm sure they'll be able to make some for relatively cheap.
PostPosted: Sun Sep 30, 2012 11:56 pm
OK, so here is my 2 cents worth, Thanks to all who input in this thread. I have gained some knowledge on the subject and an answer to one of my questions. :)
I just finished socketing my PM6 (like a week ago) and it works great. One thing I did different though. I soldered my 28 pin ZIF directly to the XRAM. It was a tight fit, but it worked well.
Next will be the SST27SF512 upgrade with switches.
A couple pics to share of my project:
PostPosted: Fri Jun 13, 2014 2:54 pm
What addresses do I need to put into flash & burn to put 2 maps on a sst sf512?
PostPosted: Sat Jun 14, 2014 5:13 pm
Nevermind I figured it out, moates 2timer ......
Users browsing this forum: No registered users and 19 guests
