It is currently Fri Mar 22, 2019 6:14 am
PostPosted: Sat Sep 11, 2010 12:11 am
full throttle shift, On auto to manual converted car.
Hey how would I wire this up.
Im guessing it triggered from the clutch pedel switch but what is this on the auto wiring?
Is it the grn/wht (pos 8) + black (pos 7) then wire them together to the clutch pedal switch? (would also mean you need to clutch to take the key out.)
Any help would be good,
Thanks.
PostPosted: Sat Sep 11, 2010 7:36 am
You would wire it to whatever input you are using for FTS, and using a switch on your clutch pedal.
PostPosted: Sat Jan 07, 2012 1:19 am
Hello there, if we using crome to set up full throttle shift, how the wiring should it be? Average i google up, all show that wiring tap from ground-->switch----> B7 pin ? it is true?
