Signed up to do a bit of research into mapping standard ecu systems, and thought id post up my little toy... Don't be to harsh... its a track car on a budget!
(Blatently Copy Pasted from another forum!!!)
Thought i might post up a few pics of my current toy... 1991 Honda City PGM-FI CZi
It's a 1.3 SOHC 16v, 100bhp (book power) and 680kg (again book weight).
The CZi came with a Cussco LSD as standard, and A/C
According to Honda only 142 were imported to the UK...
I'll keep this thread updated with the progress
Well from finally getting it out on track, i know now...
A) It's still factory limited to 110mph
B) It's AWESOME out of the corners (pushing 90% of big power stuff in the bends)
C) It REALLY looses out on the straights
D) Corners like its on rails, but body roll is silly!!!
The answer???
Coilovers and BOOOOOOOOOOOST
Weighed it this morning...
Partially stripped, half tank of petrol
672kilos
Also now decided it doesnt need the civic brakes... it was locking up at combe, with its lack of weight i don't think big brakes will do anything.
Just going to replace it with some decent spec standards... if i can find any...
Just ordered a short shifter from america... £15 including taxes... guess we'll see
Sooooo... after the i bodged the standard rad fan onto a civic rad (which is a good 3 inches bigger both ways) the fan sliced through the bottom hose...
Went for a walk over to forge motor sport (litterly accross the road from me) and traded £80 for this little lot...
Normal retail would have been £130 plus VAT... BARGIN
Also got another civic rad from work and mounted a 9 inch slimlie fan to it...
So now hopfully the cooling system is sorted...
Quickshift also fitted, makes a HUGE difference!
Next??? Blue h/t leads to match the pipes
More progress today... bye bye A/C
Good 15kg there i think
Dash has come out (only so i can sort out the aweful wiring) as has the carpet and most of the sound deadening
Also got round to fitting the OMP bonnet pins, so now i can chop the slam panel off to make way for the BOOOOST
Ahhhhhh... Herroooo...
After me and Alex had a quick session between rain showers yesterday we came up with this...
Just a rough idea of the layout... oil cooler sat in play in the wing and turbo roughly where it will sit (you'll be able to see it through the bumper... PIMP)
Playing with a few intercoolers later
Booost...
Won't be quite so sticky outy
Nothing much happening at the moment...
Spun the impellor housing round so the outlet goes stright up...
Also welded the internal wastegate shut...
Left to do... Fabricate a downpipe, pipe in the internal fuel tank, buy and work out all boost piping, oh, and fit the new engine
