It is currently Mon May 13, 2024 3:03 pm
 Post subject: SPEEDOMETER NOT WORKING
PostPosted: Wed Feb 07, 2007 4:55 pm
i have a 98 prelude....everything was running great until my speedometer decided not to work....i have two ideas of what could be wrong...the plug on the transmission or the speedometer is just gone....if anyone has any other ideas or if this has happened to them....please share because my vtec will not engage since i have a stock computer....thanks
PostPosted: Wed Feb 07, 2007 8:50 pm
Yeah, check for a bad connection on the sensor and maybe on the gauge cluster. Had one that the sensor gears poped up and off the ring but it was a 95.
PostPosted: Fri Feb 09, 2007 1:49 pm
alright thanks....my tranny is right under my engine making it very difficult to get to that sensor...if you have found out an easy way to get to that sensor...please let me know... thanks
PostPosted: Fri Feb 09, 2007 6:57 pm
It's alittle bit of a pain but you can get to it from the top on the passanger side. Use a stubby ratchet with a wobble, if you need to take it out.
PostPosted: Wed Feb 28, 2007 3:02 pm
i checked the connection on the transmission, it was fit perfect. anyways took it out and plugged it back in just to be sure. the speedometer still didn't work. then i took the speedometer out and disconnected all the wires and connected them again and still no.
So now i think that my speedometer has just stopped working. If you guys have any other suggestions of things i should check, please tell me!!
