It is currently Mon Nov 23, 2020 12:16 pm
 Post subject: base map pm6 turbo HELP
PostPosted: Wed Aug 02, 2006 10:33 am
After creating a basemap the car won't idle it just shut off, i am using this write up http://www.xenocron.com/te.php?page=basemap . I tried it 10 times using the ng60 and the ng55, what i am doing wrong.
Greetings Jelger
PostPosted: Mon Aug 07, 2006 12:01 pm
dude, im in the same boat you are in i can't get mine to idle, runs rich as hell... whats your setup...
mine is b16, 450s, t3 63/60, gm 3 bar map sensor, cannot get my car to idle, runs rich as hell.
PostPosted: Sat Dec 02, 2006 12:32 pm
Try using the stock .bin for your motor. If your running a D16A6, try the stockPM7.bin and burn it into your chip. If the car runs with the stock.bin, it's your basemap that has problems. If your have a B16A, try the stockPR3.bin.
