hi guys, new here... and i am trying to use TE with NG60 code, but wanting to run stock pm6 maps and add launch control.
i got the launch control part down, but it hesitates real bad at low rpm's at WOT.
now, i did some reading around on this site, and i read that the boost maps should be turned on, and under boost options, fuel correction should be at 100%.. now would this get it to act like a stock ecu?
i also read that using the PM7 maps is a better option.
i have a d16a6 with i/h/e, and slightly higher compression (9.3:1).. any help? links? etc? thanks in advance
