It is currently Tue Jul 16, 2019 6:46 pm
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: help a novice out...
PostPosted: Wed Sep 27, 2006 10:00 am
i've been reading in the "library" section of this site for a few weeks now and i think i've got most of it but i still got some questions.
im currently building a obd0 sohc zc engine and im shooting for 8.5:1 compressoin ratio. i want to boost 14 lbs on a 14b turbo, 450cc injectors. now would i have to get the 2.5bar map sensor? can i just run a program that someone has made in the bin file and modify it to accomodate my setup?
any help is appreciated.
 Post subject: Re: help a novice out...
PostPosted: Wed Sep 27, 2006 2:21 pm
i believe so, the stock map sensor is only good to 11 psi (or so ive read)...never been above 10 myself.
yes...if its an old bin, use a new stable rom (ie ng60, ng55) for whatever map you are going to use (ie ng60_18.bin), and paste in the fuel & ignition from another.
someone else let me know if im mistaken in any way...
PostPosted: Thu Sep 28, 2006 11:58 am
could i just open the ng55_25 bar map and use that as a base map? change the injector size to 450cc injectors and run that? cause i found a pm6 "basemap" off of xenocrone with a 2.5 bar basemap so called for the pm6 ecu.
