::ranting and raving::
All right Brettr I know what you are talking about. I fire up TE and go under File and hit Datalogger and I get the friendly reminder to check my Options, I do. I tried to calibrate my TPS but it doesn't calibrate oh well, while I'm in there I make sure everything else is set correctly; communication ports, o2 sensor output...etc etc.
I click Start Logging nothing happens I'm dissappointed but I have to get to work. 1/4 of the way to work I look down and guess what.......Damn right that bitch is logging it's ass off. I'm happy as hell all the way to work I accel and decel go into boost a couple of times, I'm cheesin' hard.
I get to work pull in the parking spot look down it's still logging, I'm ready to take my laptop in to work and play with my new readings and crunch some numbers, I turn the ignition off and lean over to save my data, but I get some runtime error and the ecucontrol plugin goes away.
I don't even go to work at this point I fire up TE again and try to get it to log, nothing happens I can't get it to log at all after 15mins of messing with it, I end up being late to work and I'm not even pissed just at the program so far.
I know I'm close WTF is going on.
