Hulog on PM7-X04 (NG60 ROM) won't datalog correct values http://forum.pgmfi.org/viewtopic.php?f=39&t=11101 |
Page 1 of 1 |
Author: | waterstrott [ Mon Jul 24, 2006 8:07 pm ] |
Post subject: | Hulog on PM7-X04 (NG60 ROM) won't datalog correct values |
Ok here is my problem For editing bins i use the realtime tuning via ostrich. That works fine. But datalog doesn't work correct. I can connect the hulog (moates) to the ecu, but once starting logging all values jump around. Correct usb drivers are installed and com ports in TE (2.5.5 with ecucontrol plugin) are set to data in system. Almost every datalogger for Honda gives same jumping values. What could be the reason? Tried 2 notebooks - same probs. Tried another hulog - same probs. |
