It is currently Tue Oct 15, 2019 8:28 pm
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
PostPosted: Mon Jul 24, 2006 8:07 pm
Ok here is my problem
For editing bins i use the realtime tuning via ostrich. That works fine.
But datalog doesn't work correct.
I can connect the hulog (moates) to the ecu, but once starting logging all values jump around. Correct usb drivers are installed and com ports in TE (2.5.5 with ecucontrol plugin) are set to data in system. Almost every datalogger for Honda gives same jumping values.
What could be the reason?
Tried 2 notebooks - same probs.
Tried another hulog - same probs.
