It is currently Thu Apr 18, 2024 4:56 pm
PostPosted: Tue Nov 29, 2005 2:00 pm
Ok, this may seem like a stupid question, but I am going to ask it anyway. I'm reading this book on RISC assembly right now, and in the first few pages it mentions that there is usually a one to one relationship between assembly and machine code. If that is the case, then theoretically, making a universal dissassembler should be as easy as reading in the machine code and breaking it into characters instead of 1's and 0's. There is probably a really simple reason why this doesn't work. I just need somebody to clarify.
--Darren
PostPosted: Tue Nov 29, 2005 3:23 pm
Machine code is relative to the processor being used, so each processor has a different set of codes. For example 03 means jump in OKI processors, it means something else for other processors.
If know all the instructions by heart, you can write code entirely in machine language. For example if you want to jump to byte 4020h on the code you can simply write 032040h on an OKI processor.
The advantage of having assembly language is that it is simply nicer to read. When you compare 032040h to J 04020h, it's easier to tell right away that we mean a jump instruction with the second one.
When they say assembly language and machine code have a "one-to-one" relation it just means that when you break down an assembly code, one line of code equals one instruction of machine code. While in higher level languages, it's not necessarily so.
Here's a code in C
If (a > b) c = a;
Else c = b;
Now here's how it translates in Assembly (my x86 assembly is not so good)
MOV A, EAX
MOV B, EBX
MOV EAX, C
CMP EAX, EBX
JA NEXT
MOV EBX, C
NEXT:
As you can see when translated to assembly, 2 lines of C code can mean many lines of assembly code. However, every line of assembly code is one instruction of machine code.
PostPosted: Tue Nov 29, 2005 9:00 pm
John, you are the man.
Ok, so machine code is not completely 1's and 0's. As you stated, 03 would be acceptable machine code. So would it be safe to say that there is actually a level lower than machine code where that 03 would be represented by say 011? Is that even relevant at this point?
I'm just trying to get a deeper understanding for how this works. As you may or may not know I'm trying to get into this 05 Accord ECU and I want to understand what I am dealing with once I find a way to get the rom off of it.
Speaking of which, if anybody has any clues as to how to pull a rom off this Hitachi chip, I'm all ears.
--Darren
PostPosted: Mon Dec 19, 2005 8:47 pm
When he used 03, he was referring to the HEX value of the Binary number used in machine code. Just like using asm is easier to understand than using machine code.. it is easier to interpret the value 0x03 rather than 00000011.b There is still a one to one translation from binary to hex
PostPosted: Tue Dec 20, 2005 2:18 am
Interesting. I started reading up on how this is done in my pic chip book, aswell as that book I borrowed about RISC chips. I figured out what it means when somebody says, "My computer has a 64-bit chip"
Apparently that means that the chip can understand an instruction with 64 1's and 0's. The implications of that could mean that there would need to be less instructions needed to do the same thing on that chip. Also, I was talking to a buddy of mine and he hypothesized that that could also be why those chips support more than 4 gb of memory, unlike the 32-bit chips we're used to working with. Because the more memory you have, the longer the address, and the entire address probably can't fit into a 32-bit instruction if you are trying to have more that 4gb of memory.
PostPosted: Tue Dec 20, 2005 2:30 am
Addressing is different than instructions. The bit size the processor is, is the instruction size. You have that part right. Addressing is done through a different logic block. So instructuction size of the processor can be different from the addressing bits.
PostPosted: Tue Dec 20, 2005 3:31 am
The way I understood it was, lets say you wanted to move a literal value to a certain register. On a pic chip you would do something like
movlw b'11111111'
movwf PORTB
Since its a 14-bit chip, when you move w to PORTB which defined as like 85h, the first 4 bits of the instruction were the movlw part, lets say movlw is 03h, in binary we're looking at 0011 followed by the 85h in binary: 10000101
so the command would be
001110000101
but that's only 12 bits....
ok I don't have the book in front of me, but as far as I understood, there are only like 20 commands for a 16f84a pic chips, so I don't see the need for than say 5 bits for the instruction.
If the 64-bit thing was only for the instruction and didn't include the address, then theoretically a 64-bit chip can have 18446744073709551615 instructions.
I would tend to think that maybe only the first 8 bits of that determines the instruction and the rest of it determines the parameters of that instruction, ie what memory address is being copied to what other memory address. If only 8 bits are used for the instruction, that leaves you open for 255 instructions, which would seem about right.
PostPosted: Tue Dec 20, 2005 4:21 am
Here this will help you out perfectly.
http://en.wikipedia.org/wiki/64-bit
