It is currently Tue Apr 16, 2024 12:47 am
PostPosted: Fri Apr 29, 2005 7:34 pm
I don't seem to fully understand how the command MUL/MulB is used in OBD1 P30 code.
The Nx.500 core pdf shows that MulB usually has an object specified after it, but many times throughout my code, I see MUL/MulB all alone...
When MUL/MULB does not have an object to multiply by, what does it do to Accumulator value?
PostPosted: Sat May 14, 2005 9:48 am
Seems like somewhere I saw a notation in a rom that shows if mulb doesn't have any commands, then:
"MULB"
actually means
"MULB A,R0"
Is this correct?
PostPosted: Sat May 14, 2005 11:02 am
Also, I wonder if I found a mistake in the NX_800.500 core PDF..
On page J-3:
Quote:
JBR obj.bit,radr
Function
if obj.bit=0 then PC=radr
Description
· This instruction jumps if the bit specified by obj.bit is 0.
but on page J-7...:
Quote:
JBS obj.bit,radr
Function
Description
· This instruction jumps if the bit specified by obj.bit is 1.
It seems like JBS function is wrong and should read:
if obj.bit=1 then PC=radr
Am I correct???
PostPosted: Sat May 14, 2005 11:03 am
In the below code, X1 is set to 0, and then used in addressing...
                CLR     X1                     ; 39C3 1 208 180 9015             X1 = 0
                L       A, #0ff04h             ; 39C5 1 208 180 6704FF           A = FF04h to A
                ST      A, 00356h[X1]          ; 39C8 1 208 180 D05603           Write A to 0356h+X1(X1=0??)
                ST      A, 0035ah[X1]          ; 39CB 1 208 180 D05A03           Write A to 035Ah+X1(X1=0??)
                ST      A, 0035eh[X1]          ; 39CE 1 208 180 D05E03           Write A to 035Eh+X1(X1=0??)
                LB      A, #0ffh               ; 39D1 0 208 180 77FF             Write FFh to A
                STB     A, 00355h[X1]          ; 39D3 0 208 180 D05503           Write A to 0355h+X1(X1=0??)
                STB     A, 00359h[X1]          ; 39D6 0 208 180 D05903           Write A to 0359h+X1(X1=0??)
                STB     A, 0035dh[X1]          ; 39D9 0 208 180 D05D03           Write A to 035Dh+X1(X1=0??)
In this case, is X1 basically ignored since it is 0? or am I understanding wrong?
PostPosted: Thu May 19, 2005 5:20 pm
1. MUL/MULB without object means the multiplier is A
2. Right, JBR means Jump if Bit Reset (=0) JBS means Jump if Bit Set (=1)
3. X1 is 0, because ST instruction has no direct 16 bit addressing mode
PostPosted: Thu May 19, 2005 6:23 pm
With MULB you need two values, the multiplier and the value to multiply it by..
Is it A and r0?
PostPosted: Fri May 20, 2005 4:08 am
The multiplicand always A or AL (MUL or MULB)
PostPosted: Fri May 20, 2005 6:58 am
My question is A * ?? = X
PostPosted: Tue May 24, 2005 2:43 am
MUL -> A,ER0 = A * A
MULB -> A = AL * AL
PostPosted: Tue May 24, 2005 7:34 am
Thank you for making that clear. Sorry for seeming like such a dumas
PostPosted: Sat Jun 25, 2005 3:34 pm
MULB -> A = AL * AL
huh? um that would be dumb. this is how it works:
MUL = er1A = A*er0;
MULB = A = AL*r0;
Ben
PostPosted: Sun Jun 26, 2005 7:37 am
Thanks for clearing that up.. I never fully accepted the previous answer.. it just didn't make sense..
