It is currently Thu Mar 21, 2019 7:52 am
Post new topic Reply to topic  [ 20 posts ]  Go to page 1, 2  Next
PostPosted: Tue Oct 02, 2012 5:56 pm
Hi. I have a rather mind blowing question for me. Here is the code sample:
label1:
                CMP    A, X2
                JLT    label2
                ;...some more commands...
label2:
                ST      A, 00000h[X1]
                L       A, er0
                ST      A, 00002h[X1]
                RT
"RT" instruction, according to "66201 Instruction Manual", is for returning from normal subroutine (subroutines that were called by "SCAL" or "CAL" commands). So, what will it do in the code above? Thanks a lot.
PostPosted: Thu Oct 04, 2012 6:40 am
When calling a routine by SCAL or CAL, the processor saves the return address ($SSP=PC+n & SSP=SSP-2).
RT instruction allows the return at the address saved (SSP=SSP+2 & PC=$SSP).
The instruction "jump" or another type of conditional or unconditional jump has nothing to do with "RT".
PostPosted: Sat Oct 06, 2012 9:35 pm
I know that. That's why I'm asking. It is actual code that works and label2 is not called by SCAL or CAL command anywhere in the code.
PostPosted: Sun Oct 07, 2012 3:42 am
put the full code or the binary file because the listing in your message is too small.
PostPosted: Wed Oct 10, 2012 5:51 pm
You're missing code flow.
Either Label1 or label2 (or label0 or label-1) could be the function call.
if you know C, think like this
void a_function(void) { a++; }
in assembly this will end up something like this:
label_a_function:
inc A
RT
When you want to use a_function, you use cal or scal a_function. You can do "bad things" by jumping in and out of functions that have pushed their return address on the stack. if you fail to pop the return address out of the stack but are "done" with the function, you can horribly smash the stack.
I'm probably not doing the BEST job explaining this but it's pretty standard programming architecture stuff. You're not looking at anything specific to the 66K here.
PostPosted: Wed Oct 10, 2012 6:27 pm
[Off topic]
Hello Blundar :D
This is very big pleasure to read you. 8)
[End of off topic]
PostPosted: Sun Oct 14, 2012 12:46 am
blundar
Thanks a lot. I understood you fully. Finally, I really missed some cross reference calls. Now I found them and it makes perfect sense to me.
P.S. Does anyone still have an OKI 66k (66201 or 66207 or 66301) User Manual? Not an instructions manual (these things are all over the place). I have found only archive with the scans with a lot of missed pages.
PostPosted: Sun Oct 21, 2012 10:40 am
UP
PostPosted: Sun Oct 21, 2012 12:47 pm
What pages do you want :?:
PostPosted: Sun Oct 21, 2012 3:30 pm
I'm missing the next pages:
1 to 12
16 to 24
page 40
58 to 66
122 to 123
132 to 148
173 - to the end
If you have any of them I will be more then happy to get them from you.
PostPosted: Sun Oct 21, 2012 3:40 pm
I don't have time for scan all pages you need.
What are the pages you need in the first time :?:
PostPosted: Tue Oct 23, 2012 3:21 pm
For the time I'm missing pages 16-24 the most.
PostPosted: Tue Oct 23, 2012 4:00 pm
Ok, I do this in the week.
PostPosted: Tue Oct 23, 2012 5:09 pm
Thank you a lot!
PostPosted: Tue Oct 23, 2012 6:17 pm
User Manual MSM66301 _ Page 16 to 24.rar
User Manual Page 16 to 24
