It is currently Tue Jan 22, 2019 6:53 pm
PostPosted: Mon Mar 28, 2011 12:39 am
I'm confused as to what to send for my MSB and LSB when reading a chip or memory via Burn2 or Demon. I know they are Most Significant byte and Least Significant byte. Least is the far right 2. So what is my command, the chip memory is 8000 to FFFF for a 32k file. What should my 'n' command be set to? I know that 0 = 256, but is that 256k or 256 bytes and if it is 256 bytes, are the numbers standing for increments of 256? If so then would 'n' not be 127 since 0 is 256?
PostPosted: Tue Mar 29, 2011 4:18 am
I actually figured this out for myself today.
Sorry for the double post, but I am sure I will have more questions in the future, thusfar I am able to read and erase all chips and my Demon memory.
I do have a question though, is 0 for n=256 the max bytes you can pull at a time? I haven't tried any other settings for n but I figured its how ever many bytes you wish to pull.
PostPosted: Wed May 23, 2012 11:19 am
i am also facing same problem of hardware commands to moates, its okay do not say sorry about your's previous post command. new post which you post about commands is too good and correct thank you
PostPosted: Wed Oct 10, 2012 5:53 pm
support@moates.net - email and you will receive help.
