It is currently Tue Mar 19, 2019 3:24 pm
Post new topic Reply to topic  [ 13 posts ]
PostPosted: Sun May 02, 2010 11:28 am
i have my serial communication setup only i tried to communicate with the burn1 for example to get the version but no response i want to know what are the commands to communicate? maybe some example code..
PostPosted: Thu May 06, 2010 3:21 am
did u check the port setting in device manger and did u install the right diver
PostPosted: Thu May 06, 2010 11:09 am
PGMFI Elf
Right on the website...
http://www.moates.net/zips/firmware/pro ... %20v19.zip
PostPosted: Thu May 06, 2010 6:26 pm
i do have that file for protocols only i send data to the burn2 and i get back ????? not the version... on that file it says to send 'V'+'V' so i don't know if i literally send 'V'+'V' or what does it send or even how to send it....i haven't done serial communication before so don't know how the protocol works exactly...if someone can chime in with some example or even some code..would be great help
PostPosted: Fri May 07, 2010 1:03 am
i do have that file for protocols only i send data to the burn2 and i get back "?????" not the version... on that file it says to send 'V'+'V' so i don't know if i literally send 'V'+'V' or what do I send or even how to send it, i mean i send in a char array containing that "string" or what?....i haven't done serial communication before so don't know how the protocol works exactly...if someone can chime in with some example or even some code..would be great help
PostPosted: Fri May 07, 2010 8:31 am
just to make it extra confusing... :wink:
RTPComm.Output = Chr(CByte(HextoLong("56"))) & Chr(CByte(HextoLong("56")))
basically output the string "VV" and wait for a response...which should be a 3 byte array; 5, ?, B where ? is the firmware version.
PostPosted: Fri May 07, 2010 11:51 am
PGMFI Elf
The Protocol guide tells you exactly what to send and exactly what to expect back. Like stated, sending 'V'+'V' or 0x5656 retrieves the three byte version of the product.
PostPosted: Sat May 08, 2010 9:55 am
thanks guys i finally got it, im doing it on c#, fastcrxsi90's post actually helped me didn't confuse me at all lol
PostPosted: Mon Sep 27, 2010 6:30 am
It is very good collection of c#, fastcrxsi90's post. I am doing two project in this topic and it is very useful for me. I can't thank you enough, it is very needed tutorial because of it I am very much appreciate to you.
PostPosted: Tue Jan 04, 2011 5:25 pm
If you write a routine to send the command byte and the checksum, the checksum for V (char 0x56) is V (char 0x56).
Thats why it sends VV. Saves you writing a routine for writing commands with checksum and one without [+]
PostPosted: Thu Jan 06, 2011 3:40 pm
good point...V for version which yields V as the checksum.
PostPosted: Thu Jan 06, 2011 7:53 pm
Yup - it would probably have been clearer if i had mentioned V for version.
PostPosted: Fri Jan 07, 2011 11:49 am
PGMFI Elf
It's mentioned in the Moates Hardware Protocols document linked above.
Users browsing this forum: Google [Bot] and 5 guests
