It is currently Sun Oct 26, 2025 4:31 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
 Post subject: Knock Sensor
PostPosted: Tue Nov 15, 2005 8:07 am
I changed my p28 for a pr3-j01 obd1 ecu with knock board. I installed the one wire for the knock and pluged it in D3. The knock sensor is from a 99 EDM VTi B16A2. Car starts no check engine. When i hit Vtec the check comes on it is for knock sensor. Any ideas? Vtec continues to wrk with check on.
PostPosted: Wed Nov 16, 2005 2:24 am
did you wire in a shielded wire and tie the shield in with one of the sensor grounds? or just run a normal wire to the sensor? if its not a shielded wire---thats your problem---it HAS to be shielded and the shield has to be tied in to a sensor ground.
PostPosted: Wed Nov 16, 2005 4:48 pm
Why? All EDM VTi Civic run a plain wire. No shields. Anyway problem is fixed now knock sensor was not torqued fully and it didn't have a good ground on the engine block.
PostPosted: Wed Nov 16, 2005 5:05 pm
What torque did you use?
PostPosted: Wed Nov 16, 2005 5:11 pm
really, usdm HAS to have a shielded wire to absorb and shunt the emi and rfi away from the sensor input
PostPosted: Wed Nov 16, 2005 11:13 pm
Nah, mine has a plain wire for most of it, never gives a code after 3 years.
PostPosted: Thu Nov 17, 2005 12:04 pm
i tried to do one on an accord h22a swap like that and every time it would hit vtec, the light would come on.
