It is currently Wed Jun 19, 2019 3:44 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 44 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri Apr 08, 2005 10:06 pm
SM = surface mount
DISC = standard ceramic disc
MONO = monolithic (the coated ones)
PostPosted: Sat Apr 30, 2005 9:20 am
kevin chen wrote:
hi i curently chipped p08 ecu as you mentioned the caps are not
necessary ,when i solder j1 jumper ,i got ecu went into limp home mode
any idea will be appreciated :cry:
Hi guys.. i'm gonna chip P08 ecu and any answer or explanation for the above?
PostPosted: Sat Jun 18, 2005 2:39 am
do you have any ideaof how to change shift points?
P30-932
PostPosted: Sat Jun 18, 2005 2:40 am
P30-932
PostPosted: Thu Jun 23, 2005 1:11 am
having a problem with a solid CEL
only happens when J1 jumper is switched to mod.
P30-932 in a 94 Civic EX-auto
28 pin dip socket, 373 latch, 2/.004uF(C49&C50), 2/.00001uF(C91&C92)
are there any other locations that I may have missed
 Post subject: P30-932...
PostPosted: Sat Jun 25, 2005 8:47 pm
I have taken out J4 and put a 1k resistor in R54.
I still get a solid CEL in mod mode.
I will try to put .1uF caps on C51&C52.
someone, anyone, out there, I'm a highly motivated newbie that needs a hand.
PostPosted: Wed Jun 29, 2005 12:55 am
whats J4 do?
 Post subject: ???
PostPosted: Mon Jul 04, 2005 6:41 pm
I read, for RTP/datalogging w/crome must remove J4. I have a P30-932 w/ JDM B16auto tranny. need to find bins that work, having setup problems.
PostPosted: Sun Sep 11, 2005 7:05 pm
To clarify,
Fitting a switch on J1 will allow switching between a Standard Map and an Modified map. I Like the sound of that :)
Regards
Chris
PostPosted: Sat Oct 01, 2005 10:50 pm
Rom socket pin 22>C29>R39(bottom)>66k pin 25
I think it's C92 if so, how to wire if traces between C92>R39 are broke?
Pin 22 and 66k pin 25 have no continuity.
PostPosted: Sat Oct 01, 2005 10:51 pm
PostPosted: Thu Nov 17, 2005 3:28 am
Sorry for asking such a noob question here. Currently a student with low pocket money(Data Logging will be my future work). :P My ride run with standard/stock B16A2 MT JDM anyway.
After reading the texts from PGMFI.ORG..seems like most of the ppl here going for data logging..
I am wondering if just changing the EPROM without using any data logging, is it means i just :
1. Bridge the J1
2. Add the 74hc373 SMD chip
3. Add a 29C256 eprom with bin written to it
or I still have to make more steps like :
4. Add C49 & C50 and C91 & C92 on back
(C49 & C50 --> .004UF)
(C91 & C92 --> .00001UF)
Currently in Penang, Malaysia and making some research on this. Also..trying hard to get the programmers and parts locally..
Thx in advance!!!
PostPosted: Thu Nov 17, 2005 11:01 am
Soree..
miss out one step:
5. R54 should be filled with a 1k to 1.2k resistor(the exact value does not matter)
BTW, I checked from the electronic shop just now. The got one super old emulator which the 5"disk installer which I never seen for about ten years.
Can I use other software on that emulator?
Thx a million times.
PostPosted: Thu Nov 17, 2005 1:48 pm
If you have the small frame JDM ECU them forget about R54, that only applies to the large frame ecu's without the surface mount components.
Users browsing this forum: Google [Bot] and 18 guests
