It is currently Tue Apr 16, 2024 2:46 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 8 posts ]
 Post subject: which chip to use
PostPosted: Thu Jul 18, 2002 1:41 pm
Ok guys, I had a couple of Generic 26C256 EPROM, but they're all used now.
I'm about to go shopping and buy some zif sockets and xxPROM.
Now, which xxPROM should I buy ? Which onw do you reccomend.
Personally I'd like to use either EEPROM or FLASH, since EPROM are more fragile...
 Post subject: Re: which chip to use
PostPosted: Thu Jul 18, 2002 1:48 pm
I'm not sure if flash are electrically compatible.
I've personally used ATMEL 27C256 OTP ROMs, National Semiconductor 27C256 EPROMS w/ UV window.
EEPROMs will probably work too...
be really careful when buying ZIF sockets.
There is not a lot of space on the PCB for the extra space of a ZIF. The ones I use you can get from digikey for ~$6.50. They just BARELY fit and they are low profile ZIFs...
PostPosted: Thu Jul 18, 2002 1:59 pm
I use the at29c256. The at28C256 doesn't work. Don't know about the 26c256 tho.
Mike
PostPosted: Tue Aug 06, 2002 12:14 am
That's cool that the 29C256 works, because they're cheaper than the 28C anyway, I'll have to try those... I agree about those Digikey ZIF sockets, those kick ass for the price and they actually fit in the footprint in Honda ECUs without touching anything...
PostPosted: Wed Aug 07, 2002 12:27 am
what speed do you guys use? I have been chipping alot of ecus lately and am out of 27c256s. I was gonna get a bunch more, but dont want some that are too slow or too fast. Does it matter? I can't afford to drop the $$ on 29s all the time. How much do you guys get them for? I really don't see paying more than .50 for 27s, and $5 for 29s.
PostPosted: Sun Aug 25, 2002 3:30 pm
120 ns or faster should work great..
PostPosted: Mon Aug 26, 2002 2:53 am
What's the digikey part number for the zif socket? I've had some low profiles laying around and put one to use the other night when a buddy brought over his pm6 and a chip. http://www.wolfenet.org/gallery/ecu you can see the socket here.
PostPosted: Mon Aug 26, 2002 11:54 am
PGMFI Elf
The ZIF socket PN is A347-ND
Users browsing this forum: No registered users and 8 guests
