It is currently Sun Oct 26, 2025 7:00 am
 Post subject: ECU Identification
PostPosted: Tue Jan 25, 2022 6:18 pm
Hey guys, I'm hoping I can get some help here. I have a J35 (from 03 odyssey) in a sandrail and the ECU that it came with has the stickers removed. I called the guy who does the swaps and he refuses to tell me what its out of.
Main issue is that the ECU's fuel pump relay wire does not appear to be working. Ive tried to diagnose it to no avail. I would also like to tap into the CEL wire, so I can have a light on the dash as well.
Any help would be appreciated!
Pics of said ECU:
 Post subject: Re: ECU Identification
PostPosted: Fri Feb 11, 2022 11:46 am
PGMFI Elf
It is an OBD2 ECU and the ID can be checked that way.
If it's in a sand rail you will have check engine lights, so it's useless to add that pinout.
Users browsing this forum: No registered users and 30 guests
