Hi
Somehow I blew up a large diode in my ECU. Does anyone know what this diode does or why it would have fried? I have an 89 Prelude 2.0 SI 4WS with a PK2 ECU. The diode is labeled D13 on the board.
Here is the full story of what happened:
Started the car in the morning and noticed the charging light flickering a little bit. Decided to check it out later and kept driving. About half way to work the engine died. The main battery (70 amp) fuse blew. Disconnected alternator and tried to start, but whenever I do that the #38 fuse (PGM-FI Main Relay) in the engine bay relay box blows. Looked at the main relay and all the wires going to it are melted, but the relay itself tests good. Traced a short on the yellow/black wire back to the ECU, where I found the charred diode. I'd like to figure out exactly what happened before I fry another ECU.
I found a few threads on Honda-Tech which I think are the same or a similar issue, but none of them were ever resolved.
https://honda-tech.com/forums/honda-crx ... s-2583069/https://honda-tech.com/forums/acura-int ... t-2865160/https://honda-tech.com/forums/engine-ma ... e-3084048/
