Mariabooker wrote:
Thanks for your post. Yes I am also used D10, to connect my wideband.Its working good.As we all know there is a lot of inconsistency when it comes to dealing with reactances of complex components. Sorry, I did not knows what are the capacitors on D10-ELD circuit to replace them.I think you will get best answer by searching through web.Please search on web and you will get what you want.I think its better one and if you do not fit with you,you can change it.And also you will better
writing tips from internet also.
thanks a lot for the replay,
found my problem , was the ECU conversion cable ( i have p30 on my crx ivt b16a1 ) , can you believe it ?
