It is currently Sun Apr 21, 2019 9:52 pm
 Post subject: Testing A/C output
PostPosted: Thu Dec 15, 2016 5:33 pm
Have a customer complaining that his compressor is stuck ON. I swapped the STA413 transistor with no change. The A/C lines are on connector A6 from STA413 pin #5 and connector B6 from H1C2 pin 21. Can someone confirm taking one of these pins "high" or "low" will activate the A/C output?
 Post subject: Re: Testing A/C output
PostPosted: Sat Dec 17, 2016 2:23 am
Did you test with A6 disconnected from the ECU plug , to see if the clutch is still engaged?
It could be a problem coming from the A/C clutch control module if this car have one.
Is it an auto or classical A/C ? Could you tell us what model of car it is?
Users browsing this forum: Bing [Bot], Google [Bot] and 21 guests
