It is currently Mon Jan 21, 2019 2:55 am
PostPosted: Wed Jul 25, 2018 7:49 pm
Hi, i have 2 issues here..
1st is a p27 ecu and a p06 ecu with the same issue, MCU doesnt seem to power up pin 32 on ic7, ive tried changing all caps, (no broken traces) replace ic17 qm3 ic7 (from a working board) also replaced another MCU from a working board and ic12, still stuck and solid cel and no fuel pump prime..
2nd issue is ac compressor trigger from ecu p27 and p28 ecu, ac compresor will on if i on ac at cluster, but once compressor is running, it wont go off even if ac at cluster is off, have to off the engine and restart it for it to go off.. tried changing qm3 but problem still persist..
Can confirm its ecu issue because have tried it with working ecu and all is fine
Any other ideas or parts for me to try and replace? Thanx in advance
Users browsing this forum: No registered users and 25 guests
