It is currently Thu Apr 25, 2024 2:49 pm
PostPosted: Mon Feb 07, 2011 9:27 am
Bro..
Wanna send it to me to hv a look?
I can't help much with picture for this case.
Rgds
PostPosted: Thu Feb 10, 2011 10:43 am
I think i see the problem.
Will confirm later and keep u updated if correct.
PostPosted: Thu Feb 10, 2011 11:12 am
yup 99% can be fix ur cel14 with hunting idle.
Let me know when u give up.
U try first.... Tq
PostPosted: Sun Mar 06, 2011 3:28 pm
Are you sure its an electrical/ecu type fault, and not a mechanical fault?
Have you checked the fast-idle valve is set correctly? . . .
I've recently experienced 2 cases where the white plastic thermo valve has un-screwed itself over time. It was also throwing a code 14 (the IACV and fast-idle vale are connected mechanically). Once I screwed the thermo valve back in everything was fine.
Just an idea to look at . .
PostPosted: Wed Jun 15, 2016 6:03 am
also see the prblm..
PostPosted: Wed Jun 15, 2016 2:59 pm
Your C28 is removed?
PostPosted: Fri Jul 01, 2016 6:33 pm
Haha bang sam, pening terus mat saleh baca, google translate pun xdapat ni.
Users browsing this forum: No registered users and 22 guests
