It is currently Wed Jun 19, 2019 2:39 pm
PostPosted: Sat May 28, 2016 3:48 pm
Hello everybody!
Recently i have helped a friend to replace his auto gearbox with a manual gearbox, on a 5th gen Prelude ( H22A5 engine ).
I have removed the RP13 O ohm resistor and put a jumper on RP14, as explained on several forums ( also as explained here on the wiki).
The car start fine ( i also modify the engine harness) and seems to idle normally but there's no vtec.
The TCM was removed from thecar but the ECU is still giving an error code 30 .
The jumper seems to be ok, so i don't understand where could the problem be, does anybody have any idea?
Thanks a lot! :D
PostPosted: Sun Jun 05, 2016 1:15 pm
Problem solved, it was a bad soldering, shame on me :oops:
Users browsing this forum: Google [Bot] and 16 guests
