It is currently Fri Apr 19, 2024 5:21 pm
PostPosted: Sat Feb 13, 2016 1:38 am
the harness has 3 insulated wires and common wire plus 4 other ones
if anyone has a busted one I would buy it for harness
or where I can get an insulated wire like that
PostPosted: Sat Feb 13, 2016 1:54 am
Phone cable are insulated if i remember correctly .
But you may buy the wiring directly to MTX, is there a part number on the cable?
PostPosted: Sat Feb 13, 2016 10:37 pm
no theres 2 parts to it
theres a plug at the end of gauge harness and theres a middle piece that has different lengths and then sensor plug
I don't really care about middle harness this gauge is gonna be permanently wired into a car and gauge cluster so I can run wires directly to sensor plug I just need to know what goes where
there are 5 wires in sensor plug but there are7 wires and a ground strap in this harness that goes to sensor
the power harness is separate and I know those colors
PostPosted: Tue Feb 16, 2016 5:40 pm
does the stock engine harness have shielded wire for some sensors?
PostPosted: Wed Feb 17, 2016 1:29 am
Ignitor sensors wires should be shielded :D
PostPosted: Fri Feb 19, 2016 10:27 am
Yup, distributor sensor wires and the O2 sensor signal wire are shielded.. Maybe others that I can't remember right now..
PostPosted: Sun Feb 21, 2016 8:09 pm
do I even need that?
seems like the sensor wire doesn't have aluminum shielding just heat shield
PostPosted: Sat Feb 27, 2016 11:16 pm
This is because when this sensor is used in a factory loom is rarely routed near high energy lines (ignition), AC lines (some sensors, alternator), or lines supplying large current (battery cables, fuse box feeds, ECT). The longer the harness the more important the shielding will become as the amount of electrical interference will compound with length. You can build your harness, then wrap it in foil or steal braided loom and ground that covering. If you use foil, rap it in tape or heat shrink to give it some protection from wear.
Users browsing this forum: No registered users and 17 guests
