It is currently Thu May 23, 2019 12:50 pm
PostPosted: Tue Nov 19, 2013 3:39 am
hi all gurus.. got this ecu p08 from d15b eg. tested and found the are 2 errors, 21 and 14.
from the picture, you can spot, part have been repaired for the vtec section. but for the iacv circuit, i have replaced the Q8, R62,R63 with well known good parts. no parted line found.
The idling keep bouncing and got CEL lit up.. forgot to mention, mostly found this error cause by broken line. there are 2 line connected from ic11 to rm1 and q27 to c55.
other parts from you all gurus can suggest to replace?
thanks in advance..
PostPosted: Tue Nov 19, 2013 5:39 am
do you want the complete diagram of the IACV part (drive and control) :?:
PostPosted: Tue Nov 19, 2013 10:06 am
yes sir, if you got it.. thanks..
PostPosted: Wed Nov 20, 2013 3:21 pm
quick, freehand :
PostPosted: Thu Nov 21, 2013 9:47 pm
thanks bro..
PostPosted: Wed Jun 15, 2016 5:38 am
invicta wrote:
thanks bro..
Hi Invicta.. do you solve the prblm?
Users browsing this forum: No registered users and 18 guests
