It is currently Fri Mar 29, 2024 4:07 am
PostPosted: Mon Jul 17, 2017 4:43 pm
Hi all!
I've build a turbo project with new 1000 cc injectors. At the first start, I did the necessary basic adjusts of injector size, copying the tables from p28 to gold, and the engine has started. Logically with the curves of fuel and ignition completely wrong, since the compression ratio and the fuel is different of stock now.
My problem starts now. When I change some values from fuel and/or ignition tables (with real time update activated or "writing" the rom), the engine does not change your behavior and the lambda value not too. An interesting detail that i noticed, after I change the values in real time or writing the rom and read the current rom in the ecu, the values are all there!
Other functionalities from "options" like rev limiter, map calibration and etc., are working normally.
I really don't know what i do in this moment.
Some one already passed by this problem?
Ps: sorry for by median English.
Info: Windows XP, Ostrish 1.x, Crome 1.6.x, D16Z6 (p28)
PostPosted: Tue Jul 18, 2017 10:16 pm
Maybe the problem should be the VTEC solenoid. Previously, check the door interruptor.
PostPosted: Wed Oct 04, 2017 12:14 pm
Ecu problem
Users browsing this forum: No registered users and 11 guests
