Hi, i am looking for honda ecu to suit my needs. I want the ecu to have launch control, and to handle 2 vtec solenoids and boost ... i want to try to fit honda ecu to my nissan with neovvl head from primera p11 with 2 independant solenoids (on/off type from rpm to rpm)... so if you have any suggestions, please help. I think i can use the idle control valve for the secont vvt solenoid, but i am not sure ... also, what trigger is using the honda? i dont think its a big problem to use honda ecu for this ... but i want to know whats the best combo ecu with rom for turbo setup like this. also whats the suggested rom tables resolution for timing and fuel tables. i hope you can help me ... thanks.
Knock detection is not needed, but its good plus i think.
Also, any chance to have COP setup? i have 4 coils from cr1000 prepared for my car ... and i want to use them. I want to change my megasquirt with more reliable ecu like honda one ... please help
