Hey i am kinda new to all of this but I am running a d16z6 in a crx on a dirt track. i have a problem with it seeming to go into limp mode after about 3-5 laps. I am running it on a basically a stock p28 file in a chipped p06 with vtec enabled. Only thing I really changed on the tune with chrome is raising the rev limiter slightly and dissableing as many sensors as possible. I changed the coolant temp sensor and it seemed a little better but still didnt cure the problem. have tried running it on a stock p28 ecu and a stock p06 and get basically the same results. i have a light on the dash to know when vtec is engaged and I will loose vtec about 1 lap before it shuts down. if I lift and coast at that point it seems to last a little longer but vtec never comes back on. could it be due to the fact that the crx tranny doesnt have a vss? thanks for any help
