Joined: Sun Mar 08, 2009 11:12 pm Posts: 100 Location: Malaysia
To all Master... I got recieved 1 P30 ecu with error code 14(IACV) and 41( Heated oxygen sensor heater). ecu history; used hondata before this and prblm with CEL .. suspected the hc373 ic prblm. i try to removed J1 to run in stock mode but same problem with CEL ON. jump diagnostic and found error code 14 and 41. the ecu looks nice and no burn/ open circuit. For error 14, I did check the continuity from q29 to pin # 62 main processor,ok. Is't because of J4 open and function???what else that i need to check/change for this 2 error code.. appreciate for your help....
