e-tech wrote:
monster222 wrote:
yesterday i changed all the leaking caps from a working p08
after cleaning all the left over juice and solder in new caps, it is throwing code 3 map sensor..the car run horrible now
which part should i check?
Bro....
Check C32 and the surrounding area....
Broken connection.....
i clean all the trace and check connection with multimeter..everything is good.
i removed J1 and the CEL is gone
this ecu is also socketed by me..put in a crome gold bin with boost column added..the car is a turbo D15B
and yes..the main processor is ST
