sicknastyb17 wrote:
well he stated the h22 bin has 2step I highly doubt he has a eprom programmed with a 2step working on a p13 base. Not many people can do this, so I assumed it was a h22 basemap written on another rom.
Correct
I have a stock P13 that it runs great on but I want tune ability.
I am getting a cel for egr on the P13, the egr is not hooked up and will be removed once I get a block off plate.
I have 2 different chips, both are stock base maps for the H22 with different launch control settings and vtech cross over points.
As stated before, I get a solid cel and when I try to pull the codes it stays solid.
And I'm sure the maps on either chip is not loading because launch control is not engaging.
I have ran both of these chips on a friends p28 with no issues.
Thanks
