It is currently Mon Jun 24, 2019 12:01 pm
PostPosted: Mon Feb 07, 2011 12:00 am
hi to all gurus and sifus..
Got 1ea p08,chipped.. the board just nice, no burning mark or leak caps.. hooked up, check for error, nothing.. when start, the idling running like hunting at 1.2-1.4k.., for 4-5 sec then come the error..
Disable the chip also gave same result.. connection from A9 to D1594, good.. Change the D1594, oso same.. Both nearest resistor gave 1.2 ohm, replace still the same.. q27.. huhuh..
hmm.. got no idea now.. can anybody give some advise on this?
Appreciate if any idea to try. Thanks in advance..
PostPosted: Mon Feb 07, 2011 9:27 am
Bro..
Wanna send it to me to hv a look?
I can't help much with picture for this case.
Rgds
PostPosted: Wed Feb 09, 2011 5:31 am
hmm. .. i think need to figure it out by myself first la bro.. any idea?
PostPosted: Thu Feb 10, 2011 10:43 am
I think i see the problem.
Will confirm later and keep u updated if correct.
PostPosted: Thu Feb 10, 2011 11:12 am
yup 99% can be fix ur cel14 with hunting idle.
Let me know when u give up.
U try first.... Tq
PostPosted: Fri Feb 11, 2011 3:21 am
hmm.. almost 10pcs component replaced, still the same.. chip or not, still the same..
blurrrr.... :)
PostPosted: Sun Mar 06, 2011 3:28 pm
Are you sure its an electrical/ecu type fault, and not a mechanical fault?
Have you checked the fast-idle valve is set correctly? . . .
I've recently experienced 2 cases where the white plastic thermo valve has un-screwed itself over time. It was also throwing a code 14 (the IACV and fast-idle vale are connected mechanically). Once I screwed the thermo valve back in everything was fine.
Just an idea to look at . .
PostPosted: Wed Jun 15, 2016 6:03 am
also see the prblm..
PostPosted: Wed Jun 15, 2016 2:59 pm
Your C28 is removed?
PostPosted: Fri Jul 01, 2016 5:11 am
hi bang majdi... hehe.. :D
kes lama ni..
-sam as-
PostPosted: Fri Jul 01, 2016 6:33 pm
Haha bang sam, pening terus mat saleh baca, google translate pun xdapat ni.
Users browsing this forum: No registered users and 27 guests
