A customer brought this ECU to me to get chipped to run a modified CRX. I've never seen this particular model but it has an area silkscreened for an EPROM and a latch. The barcode reads 37820-PM9-A00, 240-108829 ZA. The processor is an M66301 and is running code 214. The board also has 01D01360-1500-0 silkscreened on the right and Q7Y-DO on the bottom right. On the top right is 'CN3' which looks identical to the OBD1 datalogging port.
Research tells me this is a 90-91 USDM D15B DPFI ECU but the code is for a USDM P74 Integra B18. It's obviously "chippable" but "J1" near the datalogging ports already has a jumper so it's not the same as OBD1 in that aspect.
Can anyone shed light on this?
