It is currently Wed Jun 19, 2019 2:27 pm
Post new topic Reply to topic  [ 244 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17  Next
PostPosted: Sat Jun 28, 2014 10:44 am
Finally sat down last weekend and got everything laid out on the breadboard and working 100%.
Ended up using two minis, they take up less board space than I would take up using two sockets/controllers/crystals/etc. It's also easy to reprogram in-situ with an ftdi breakout cable and they have their own reset switches. The one on the right handles VSS via a TIP120 transistor and the one on the left handles the distributor signals via the MAX235 chip. The MAX235 is a little expensive (Maxim will send you a free two piece sample though) but it has five level converters and internal caps so it makes a nice clean install.
The rest of the board looks the same for now:
That was my first attempt at using a perfboard so don't judge too much :)
Works well so far but it's a little clunky since it's a big mess spread out over two boards. Spent the bulk of last weekend just using it, all I really wanted was to pick apart the serial packets coming from my Demon. I'm going through and laying everything out in Eagle now. I may or may not do anything with it but I want to at least get it all documented.
PostPosted: Mon Jun 30, 2014 11:12 am
Site Admin
If you at least have a hand drown schematics, send it to me, I'll try to make a layout out of it.
PostPosted: Wed Jul 02, 2014 12:30 pm
Thanks, I'm already chugging through it all in Eagle. Only way to learn is to do, right?
PostPosted: Mon Jul 14, 2014 12:35 am
So I guess you weren't getting code 9 with this board that I can create on ANY OBD1 ecu using the moates engine Sim.
(Check rpm around 2000-2500 and again at 6000rpm ish for injectors getting out of sync) Then code 9 if you transistion out of 1800-2500 too many times
PostPosted: Mon Jul 14, 2014 5:21 am
Why you have used two Arduino module when one is enough for everyone to do :?:
spAdam wrote:
PostPosted: Wed Jul 16, 2014 11:34 am
I wasn't good enough at programming so I made up for it with more hardware :)
In all seriousness, one handles the distributor sim and the other handles VSS. I haven't seen anyone else doing VSS pulse. I'm sure there's a way to pull it off with one but I just wanted to get it working so I could finally use the damn thing.
PostPosted: Fri Aug 01, 2014 8:37 pm
What is the minimal set of signals to get the ECU to start sending out ICM signal on a bench?
I am using stm32f4 for my controller and MAX232 for zero crossing. I've generated the three VR signals which seem to be close enough and powered the ECU with +12. The ECU does output +5v on TPS/MAP vcc lines, I also see that my signal gets processed by the VR conditioning circuits - I've connected logic analyzer to HIC1 pins 10, 12 and 17. What am I missing? I would expect something on line A21 - ICM Output - but nothing so far.
I guess I should figure our how to get the check engine line to blink out a code.
PostPosted: Sat Aug 02, 2014 5:47 am
Output ICM is open collector ouput.
Add pull up resistor to +12v (ex: 1k)
PostPosted: Sun Aug 03, 2014 10:37 am
Yep. Iirc (board is put away right now) I had to use a 3.3k resistor before I stopped getting ICM errors.
I also found that running the icm on its own loop (A21 --> LED --> resistor --> A23) with nothing else on that ground helped with stability for whatever reason. Otherwise it would run for only a few seconds before throwing a code.
PostPosted: Mon Aug 04, 2014 10:47 pm
Ohh, right - this explains everything! I've got the ICM signal, thank you!
Do you guys know anything about transmission control signals? I am having some ~40Hz noise on the trigger lines when I am trying to use my own standalone - see viewtopic.php?f=6&t=23979&p=138991#p138991 for details
PostPosted: Wed Aug 13, 2014 9:06 pm
So I am sending out three signals using MAX232 and the ECU does respond with some ICM signals - but ICM control mode is pretty much repeating my TDC signal. I am trying to apply different voltage at MAP sensor input wire but timing stays the same. I wonder if my ECU is in some sort of limping mode?
The shape of the signals I generate is visible in my previous message. Any suggestions?
PostPosted: Thu Aug 14, 2014 2:29 pm
I'll check, on my system, the phase of the three signals, and compare if it corresponds to the phase of yours.
:arrow: Phase CYL/DTC/CRK est very importante
PostPosted: Sat Aug 16, 2014 11:04 am
Pulsewidth too. It's all about getting the zero crossings lined up in a way that the ECU recognizes it. It took a little bit of playing around to get it to a place where it was really stable.
PostPosted: Sat Aug 16, 2014 1:41 pm
PostPosted: Thu Aug 21, 2014 8:33 am
dip wrote:
Thank you Dip, I really appreciate the picture! I've just implemented the same signal shape.
Looks like my under-provisioned 0.1uF caps on max232 cannot keep up with idle RPM, waiting for 1uF caps to show up on Monday.
Users browsing this forum: No registered users and 16 guests
