It is currently Fri Apr 19, 2024 2:55 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
PostPosted: Mon May 01, 2006 10:14 am
Ok im having a problem on our race car. I converted both the p28 and the p06 (vtec) from auto to manual. I followed the Wiki instructions to a T, and they look exactly the same as the pictures.
Anyways, i dont even think thats what the problem is, but there is the info.
Also the car is running an obd2b f23a vtec. I had to wire in the obd2 distributer for obd1, since the obd1 dizzy did not line up properly.
The problem is, when in first gear, and in neutral, it will only rev to 5k, but in 2nd-5th the normal rev limit kicks in. Im using the p30 jdm maps with the fuel tables edited for a 2.3, and crome pro.
Can someone check this map to see if there is anything majory wrong with it? Its just my BASEMAP, still have to log and tune. Thanks. Also any other ideas as to what it could be? Mechanical, electrical, etc.
