It is currently Mon Oct 19, 2020 11:16 am
PostPosted: Mon Jun 22, 2020 11:22 am
Has anyone been able to troublehoot these and fix them? I have a good collection of bad boards with ignition codes and would like to repair them.
PostPosted: Wed Jun 24, 2020 7:51 am
18 views and no response? What happened to the great contributors that were on this forum?
PostPosted: Thu Jun 25, 2020 1:22 am
Simply connect all supply and ground pinout.. Inject 5-12v pwm signal to pin ckp, cyp and tdc. Then just test with oscilloscope the output signal. Common problem is the ic problem or any short or open circuit.
viewtopic.php?t=23592
PostPosted: Sat Jul 25, 2020 8:58 pm
Theres a aftermarket board you can replace it with that Honda Rulez made.
PostPosted: Sun Jul 26, 2020 7:00 am
Are you sure it replaces H1C1 & H1C2?
I know there is a Coil on Plug board which I sell and it looks similar but I have not seen a product that replaces these boards.
PostPosted: Wed Oct 07, 2020 10:17 pm
I hope these help
PostPosted: Sun Oct 18, 2020 11:46 pm
Would these boards throw a icm signal loss code?
