It is currently Sun May 12, 2024 8:39 pm
PostPosted: Fri Jan 16, 2004 5:40 am
I wrote this asm editor with syntax highlighting for dasm662 files. Get it here if you want it:
<http://www.radicalperformance.com/download/okiedit.zip>
password is 'pgmfi.org'
Here's a screen shot:
I'll probably link it to A1k0n's assembler and disassembler plus other stuff, but for now it is just a notepad with syntax highlighting.
PostPosted: Fri Jan 16, 2004 6:04 am
nice john...
PostPosted: Fri Jan 16, 2004 6:09 am
search(ctrl+F) not working?
PostPosted: Fri Jan 16, 2004 2:10 pm
looks good man...
PostPosted: Fri Jan 16, 2004 5:10 pm
Sexy! [Thumb Up]
PostPosted: Sat Jan 17, 2004 1:38 am
OK calvin, the search thing is implemented. But I got something even better... There are two new navigation buttons that will allow you to jump to labels quickly. The 'next' button will work if the cursor is currently at a label after a jump instruction (ex. J label_0102 or JGE label_3324). The 'prior' button will allow you to back track the jumps -- very useful when trying to trace routines. More to come. But for now, enjoy!
PostPosted: Sat Jan 17, 2004 12:47 pm
John: I like your program and was wondering if I could adapt it to do the same thing for 8051 asm? It uses some different syntax on the dasms... Do you use an external rulefile, or is everything hard-coded? I would have no problems at all doing the code changes myself if you would mind emailing me the appropriate piece of code for the parser, as I know you are really busy and I wouldn't want to distract you from your other projects. Let me know.
btw, blundar@atheist.com or admin@pgmfi.org are a much better email addresses for me than blundar@codyscafe.com or blundar42@hotmail.com, both of which you have used at one point.
thanks
-Dave
PostPosted: Sat Jan 17, 2004 2:59 pm
Damn website is down... Here the prog for people who missed it the first time.
PostPosted: Sun Jan 18, 2004 10:47 am
looks nice
PostPosted: Mon Feb 09, 2004 8:17 pm
Awesome!
