It is currently Fri Mar 22, 2019 6:31 am
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
 Post subject: Re: 66507 DASM
PostPosted: Tue Apr 08, 2003 7:12 pm
Pelegri
thanks for the offer i'll send mail address so you can send photocopy of 66301 manual
PostPosted: Wed Apr 09, 2003 6:55 am
Javier,
Yes, i have probleme in MUGENXH4 with some OpCode:
$1E7A 0700 = MAC ?, push ?
$2551 544C = ?
$2553 544C = ?
$2548 545F = ?
$254A 545F = ?
$3024 549C = ?
$3355 54AC = ?
$3475 54AC = ?
$3109 54D3 = ?
$310C 54D3 = ?
$031C 5580 = ?
$035A 5580 = ?
$036B 5594 = ?
$030B 5595 = ?
$35A3 56A6 = ?
$2F92 56BB = ?
$2EF9 56D9 = ?
$3415 56DB = ?
$03AF B45D7D = ?
$265D B48E1E = ?
$265A B48E7D = ?
$2CFA B4D77D = ?
Error of my OpCode list ?
Error of Nx8/500S Info Data ?
Have you info ? or help ?
PostPosted: Wed Apr 09, 2003 8:58 am
i'll see what i can do....
just remember that nx8/500s is for 66589, not sure how much it applies to 66507
but thanks again for your effort
PostPosted: Thu Apr 10, 2003 10:51 am
I have 6 Canon IR400/IR550 Scanner/copier/fax things at work.
I can scan a 300 page document in about 2 minutes.
I'll email you my address Didier...
PostPosted: Fri Apr 11, 2003 3:16 pm
Bonjour Blundar
Je peux t'envoyer un exemplaire en meme temps que l'envoi à Javier, mais je n'ai pas recu ton adresse par mail.
A bientot
PostPosted: Fri Apr 11, 2003 5:26 pm
what??
PostPosted: Sat Nov 01, 2003 11:11 am
I was trying to use the other 66kdevtools to DASM an OBD2 rom, it appears THIS tool is the right tool.
I can test, and try to help.
-PHiZ
PostPosted: Fri Nov 07, 2003 5:17 pm
New beta version
PostPosted: Mon Dec 08, 2003 7:56 pm
merci beaucoup Didier!
Mon ami Chris D. a cherche' pour les MCU flash - les 66Q573, 66Q577, etc. Il me dit qu'il y a BEAUCOUP des MCUs flash sur le market ...
Les ECUs OBD2B utilise le MCU 66689 - le CTR 66Q589. Le hardware "JTAG" est toujours possible - comme l'EPROM pour les ECU OBD1.
Je pense qu'il peut etre plus facile a' faire un adapter pour les MCU flash (comme le 66Q573 pour ton ECU) avec le JTAG circuit pour ISP updates...
Pardon le francais miserable, et au re-lire. :)
PostPosted: Wed Mar 10, 2004 4:48 pm
New of 03/2004
