It is currently Wed Mar 20, 2019 7:32 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: 66K Disassembler
PostPosted: Tue Jan 28, 2003 1:50 pm
I am getting the 66201 manual uploaded in PDF version . It has all of the opcodes bookmarked. Look in the OBD1 forum. I am also converting the 66207 incomplete manual to PDF....
PostPosted: Tue Jan 28, 2003 5:11 pm
Fantastic. I gave up on converting it - my attempts produced some odd results & it didn't pick much text out at all 8o(
PostPosted: Mon Feb 17, 2003 6:38 am
Assembler question
What will result in acc of the following code.
LB A, r0 ; r0 -> Al DD = 0
L A, 06 ; Acc = ?
Thanks
Tony
PostPosted: Thu Mar 06, 2003 5:23 pm
I believe...
AL = 06
AH = Untouched
Somebody correct me if I am wrong.
PostPosted: Sun Apr 27, 2003 11:57 pm
Please which is the disassembler for the 66x301
Is it the same as the 66201
PostPosted: Mon Apr 28, 2003 4:26 am
Ignore last post,
I just loaded and run the 66201 one halfway down this post, and it says OKI 66K Disassembler for 66301/66201/66207 Processors.
Great work Doc!.
Dissassembed PW0mm.bin now I have to integrate Pelegri's dataloging code.
Still haven't found an assembler, I'll have to get help from a programmer mate.
Is there a 66301 assembler out there?
PostPosted: Mon Apr 28, 2003 2:04 pm
I think everyone has been assembling by hand...
I caution you that there are known problems with the disassembler that Doc wrote that involve handling the 16/8bit instructions that share a common opcode. DD status register, blah blah blah. I should make a FAQ entry about this.
Bottom line: try disassembling just the area of code you care about as opposed to the whole ROM. You'll have much more accurate results.
PostPosted: Mon Apr 28, 2003 2:48 pm
Thanks
PostPosted: Thu Jan 05, 2012 1:18 am
How can we assemble back asm file to bin file? i give a try using asm66k.exe but it cannot run on win xp, any one have manual to used asm66k.exe to assemble back asm file to bin?
PostPosted: Tue Feb 07, 2012 4:01 pm
I am not seeing the download links to download this assembler. Can someone re-upload the files or at least point me in the right direction? Thanks in advance!
EDIT: Nevermind, I found a copy of it on another site, but it would be nice to have the attachments show up for the original post.
PostPosted: Tue Feb 07, 2012 7:54 pm
Send me your "asm" file, and if file is correct, i create bin file for you.
