It is currently Thu Nov 26, 2020 12:35 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 16 posts ]  Go to page 1, 2  Next
PostPosted: Mon Oct 20, 2003 12:30 am
what's the multiplier setting for a dohc zc.
Thanks
PostPosted: Mon Oct 20, 2003 3:56 pm
PM7? 00 01 01 02 02 02 03 03 03 03 03 04 04 04 04
They are at memory address 0x3FF1.
PostPosted: Wed Oct 22, 2003 12:55 am
All I want to do is make the base turbo tune for PM6 and make it work for a ZC motor. Do I need to change to those fuel multipliers?
PostPosted: Wed Oct 22, 2003 12:46 pm
No, you need the values from the fuel and ignition tables as well as the multipliers for the ZC..
Sorry to say, but it would be easier to use (EDIT)"another editor"(/EDIT). Export the maps from a PM7 (the ZC ECU) then open the PM6 ROM, and import those maps in. It will automatically import fuel multipliers with the maps. :-/
Post Edited (10-23-03 17:35)
PostPosted: Wed Oct 22, 2003 8:27 pm
Ouch...
PostPosted: Thu Oct 23, 2003 12:05 pm
..it's just a lot of people don't know how to use a hex editor to change data int he ROM. After the maps are imported and saved it can then be edited again in GhD... :(
Post Edited (10-23-03 12:10)
PostPosted: Thu Oct 23, 2003 2:36 pm
So basically I just need to open the PGMFI_ROM-Boost.bin, then IMPORT the PM7 tune and that's it right?
PostPosted: Thu Oct 23, 2003 5:03 pm
The last version of GhD actually supports multipliers. Nice plug tho
PostPosted: Thu Oct 23, 2003 5:36 pm
..but, correct me if I'm wrong, you have to import the maps through a (EDIT)"another editor"(/EDIT), like I had stated?
Multipliers alone will not allow the maps to run a DOHC engine. The values themselves would need to be there, yes? ..and hand typing them takes so long. So I offered another solution.
Post Edited (10-24-03 22:46)
PostPosted: Thu Oct 23, 2003 5:45 pm
I would like to comment to the both of you that I use both of your editors and they both will always be on my hardrive. Because I would use something over the other one doesn't mean that I have favorites over them. I wouldn't let it bother either of you. I remember when a few people over a year or two ago would agree that hacking into the ECU would be almost impossible and this was about the time I wanted to "DO" something about it. I was about to buy a Gold ZDYNE, but now I don't have to. The ground that's been covered between that time is absolutly amazing to me...
.. but anyway. To answer my question. Is that all I have to do? I noticed that all the values changed when I imported the PM7 tune over the boost bin.
Thanks
Graham
PostPosted: Thu Oct 23, 2003 5:56 pm
..that's because the pulse durations are different, but yes, that is all you have to do.
Post Edited (10-24-03 22:44)
PostPosted: Thu Oct 23, 2003 6:31 pm
Jason, if it makes you feel better, your editor, *TURBOEDIT*, is awesome.
Keeping your cool is more important than fighting over absolutly nothing.
PostPosted: Thu Oct 23, 2003 7:16 pm
<edit> This doesn't belong in public, sorry </edit>
Mike
PostPosted: Fri Oct 24, 2003 3:33 am
(EDIT)..agreed..(/EDIT)
Post Edited (10-24-03 22:48)
PostPosted: Thu Oct 30, 2003 12:41 pm
so this will work on my tubo'd dohc ZC???
